02-10-2023 10:19 PM
Our doorbell shows no events recorded for today although there was activity. Our subscription is good, the doorbell function works and rings on our nest hub, and the live function works. Using the troubleshooter says "We couldn't find any Wi-Fi data from your camera. If you recently installed it, wait a couple of hours then try this troubleshooter again" which isnt much help considering it's connecting to everything else on wifi. I reset the camera using a pin with no change. Any ideas?
02-15-2023 02:56 PM - edited 02-18-2023 03:01 PM
Hi PaulF1,
Thanks for reaching out here in the Community and for sharing your issue with us. To confirm, what is the light status of your Nest Camera now? Is your Nest Camera on the same home structure where you applied your Nest Aware subscription? How is the Wi-Fi connection in that part of the house?
Give these steps a try:
02-18-2023 03:01 PM
Hello PaulF1,
I'm dropping by to ensure that everything is covered here. How's it going with your Nest Camera? We would appreciate it if you could share with us the information I’m asking above. Also, were you able to perform the steps I’m suggesting? We'd be glad to hear from you.
02-19-2023 03:21 PM
Dan
