3 weeks ago
Help oh wise ones... I have 2 original Nest cameras that work flawlessly. I've tried to add a new Google/Nest battery camera. Must use the google home app. I've followed set up instructions and all troubleshooting tips including resetting (starlink) router, resetting battery camera, turning off/ on bluetooth on my iPhone 16, moved device within 3 feet of router, kissed it on its head and prayed to the wifi gods.. It is unable to connect to wifi in the home app period. I tried all steps in order they recommended within troubleshooting scripts. Starting to loose my sense of humor. What am I missing? Why are we able to purchase these devices only to not be able to use them? There are too many people with this issue without a solid response from Google. Class action catches attention. Thank you in advance if you can keep me from poking a stick in my eye.
3 weeks ago
Were you able to resolved this? We have the 2nd gen camera (battery) for outdoor, we changed modem. I have to factory reset our doorbell and was able to connect , but there’s outdoor camera won’t connect at all. We even have a WiFi extender near it. It’s so frustrating.
3 weeks ago
EnclaveRes, I haven't received a reply or found the solution and frankly I'm thinking of trying to return the device and go to a competitor. It just shouldn't have to be this difficult and the merge of Nest with Google has done nothing but muddy the great brand of Nest.
3 weeks ago
I’m sorry to hear that, but good news on my part with my outdoor camera, it finally connected. The steps that I did is as follows:
1. I used a push pin to used on the reset button, the status light will
turn off, and then turn solid white after a few seconds.
You'll need to keep holding the restart or reset button to factory reset.
2. As you continue to hold the restart or reset button, your camera will count down to its factory reset and the status light will blink yellow. Your camera will also play a countdown tone.
3. The status light will appear solid yellow when the factory reset has begun. Your camera will also play a tone to confirm the factory reset.
4. Then I quickly added it to my google home app.
i hope this helps.
3 weeks ago
So glad you got that worked out and huge thanks for laying the steps out. I've reset my camera several times without luck unfortunately. I appreciate you sharing your process I'm certain it will help someone.
3 weeks ago
You're welcome, I'm sorry your camera isn't working. For some reason it's happening to a lot of people. And most of the time, no one is replying to anyone.
3 weeks ago
I agree, it shouldn’t be did hard. We also have ring camera and we never had an issue with it.
3 weeks ago
I have the same problem every month. I unplugged my wifi & wait 20 seconds. Amd plug it back in & restart my phone. I keep on doing that until it work.
3 weeks ago
It has to be a built in bug that never got fixed or something
3 weeks ago
I had the same issue, it also kept turning off so I missed a lot of security footage. I have given up and replaced it with a Eufy which is 100 times better on everything.
2 weeks ago
I think I'm going to do the same. Thank you for the lead on a good system. I'm going to take a peek.
2 weeks ago
Hi kikicoyote,
Thanks for reaching out to our community.
I'm sorry to hear you're having trouble connecting your new Google Nest Camera (battery) to your Starlink WiFi network. It's understandable to feel frustrated when a new device isn't working as expected. I appreciate the troubleshooting steps you’ve tried to resolve the inconvenience and letting us have important information, such as your original Nest cameras working flawlessly. No worries, help is here.
To better assist you, I would appreciate it if you answered the following questions:
In the meantime, please double-check these common recommendations:
Virna
