01-28-2023 02:54 AM
My outdoor battery camera wasn’t working so I followed the suggested Google steps to disconnect from my home account, then factory reset the camera. The camera is not resetting at all - not lights on. It’s essentially a dead unit. I’ve also tried to reset it when plugged in to the charging cable and also unplugged to the charging cable. Is there anything else I can do or is it just broken??
01-28-2023 07:23 AM
I have the same problem though mine is wired....only 3 years old but out of warranty.
01-28-2023 09:12 AM
Mine is under a year old so should be still in warranty but it’s not great that I need to replace it
01-31-2023 05:07 PM
I’m sorry to hear that. Thanks for taking some steps to isolate the issue — it’s a big help. Let’s further check — could you plug it into another power outlet and let me know how it goes?
02-03-2023 07:16 PM
I appreciate the help, JT.
Archie
02-05-2023 04:18 PM
Thanks for chiming in, Archie.
