06-01-2022 01:24 PM
Hi, I need a new mounting plate for my nest doorbell battery (screws got stripped trying to install original one and now I can’t remove the mount). How might I get one?
06-02-2022 08:05 AM
Thank you for your patience. We do not process these requests in the Nest Community Forums. If you are seeking a replacement, please note that unless the device is under warranty, we cannot issue a replacement.
Please first fill out this form so Support can collect some important information from you. Once the form is submitted, you will have your case number.
06-06-2022 08:16 AM
Just checking in to see if you have had the chance to fill out that Replacement form? Please let me know if you need further assistance.
06-09-2022 08:17 AM
