02-03-2023 09:57 AM
Does anybody have any suggestions on how to unstick the locking pin in order to mount my Google nest doorbell to the metal plate mount?
I removed the doorbell and brought inside to recharge. This was the first and only time I had to remove the doorbell from the mount to recharge. It has lasted over a year since installation. And now it will not mount to the plate.
As usual, the warranty on my doorbell has now expired.
02-08-2023 08:38 AM
I can imagine it has been an inconvenience, and I would love to look into this further for you. Have you tried to use a pin or needle to loosen it? Does it look jammed, and stuck, or is it missing?
02-12-2023 04:52 PM
Hey IndiaaP,
I appreciate the help, Emerson.
02-13-2023 06:01 PM
Hello there,
