08-21-2025 12:58 PM
The camera is a wired camera. But it said low battery and now the battery is off
08-21-2025 01:42 PM
That shouldn't happen. Is your camera on a switched circuit? If so, is the switch always on? Is the USB plug seated firmly in the base of the camera?
In the Google Home app, under Settings | Battery for the camera, it should always say "Plugged in" with an infinity symbol.
To contact Support:
3. Select your device from the dropdown, click "Other", then click "Next step".
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
08-21-2025 02:38 PM
Just to add to this discussion. I recently had to replace the cord on my outside Nest Camera. I was wired but showed low battery then just died. Luckily I had a device with a replaceable wire so did that and now working fine.
