03-11-2023 04:29 PM
I mounted the Nest Doorbell several months ago. I took it off to charge the doorbell but now I am unable to get the Doorbell to attach to the base plate. I have tried many options with no luck. Help!!!
03-13-2023 12:24 PM
You might have to resort to contacting Google Nest Support (https://support.google.com/googlenest/gethelp) for a replacement for your doorbell.
03-15-2023 01:23 PM
Hello everybody,
@Trollpe, thanks for reaching out. To know more about this, could you tell us what type of Nest Doorbell you have? So that we can check and give the options needed.
03-18-2023 04:09 PM
Hey Trollpe,
I'm dropping by to ensure that everything is covered here. How's it going with your Nest Camera? We would appreciate it if you could share the information I’m asking above. We'd be glad to hear from you.
03-18-2023 04:45 PM
Hello - we have a Nest Battery Doorbell. We have removed and replaced several times to charge so we know how to do that. It still won’t mount on the wall plate.
Thanks -
peter
03-21-2023 03:57 PM
Hello Trollpe,
Thanks for getting back to us and for sharing that information. We'd be happy to take a look into this for you. Please fill out this form with all the needed information. Let me know once you’re done.
03-24-2023 04:03 PM
Hey Trollpe,
I wanted to follow up and see if you were able to fill out the form? Let me know if you have additional questions.
03-25-2023 03:20 PM
If you are outside the warranty and can't get a replacement, the device is still usable if you can figure out a DIY mount, or want to resell on ebay or similar it for someone else to figure out. To fool the device into thinking it is mounted, use a small strong flat magnet. When looking at the back of the device, the internal switch area is a bit above and to the right of the wiring screw/hole on the right. Slide the magnet around until you find the right spot, and hear the interior switch click on and see the green light come on and camera functioning. Use a bit of duct tape to keep the magnet from sliding out of place, and then figure a way to mount the device. You can use velcro, zip ties, metal hose clamp, or just shove it in a flower pot, set it on a ledge, etc.
04-04-2023 06:52 PM
Trollpe, how’s it going? Did you get a chance to try the suggested steps by lextron? If so, how did it go? Let us know if you need anything else.
Thanks for the help here, everyone!
04-08-2023 03:24 PM
Hey everyone,
We wanted to follow up and see if you are still in need of any help. Please let us know if you are still having any concerns or questions from here, as we would be happy to take a closer look and assist you further.
I appreciate the help, JT.
04-10-2023 11:00 PM
Hey Trollpe,
