What is a current manufacture date for a Nest battery doorbell?
Guarneri
We just purchased a new Nest doorbell (battery version), and the MFG date by the barcode is 05/2021. Is this old inventory? What is a current manufacture date for this product?
Will this model have limited functionality compared with models made in 2023/2024? Will the battery be degraded for an unused unit that is almost 3 years old?
jenniffert
Hi @Guarneri,
Thanks for posting. I'd be happy to help you with your concerns. It would be very helpful if you could share a photo of your Nest Doorbell (battery) to determine the manufacture date.
I've also shared a warranty checker widget with you. You can use it to check the warranty of your device: Warranty Checker.
Jenniffer
