camera not lightening up
Aahluwalia
no power to the camera . i unplug  it an plug it back and still it's not lightening up
EmptyNester
Silver Product Expert
So it sounds like either camera is bad or the power supply has gone bad.  Do you have another camera / power supply you can try swapping just to test it?
If it is under 1 year old then Google will most likely honer their 1 year warranty and replace either part.  It is longer than a year you are out of luck.
Here is the link to open a support ticket if you want to which will get help directly from Google...
