nest home doorbell battery won't connect to home app
tyroneg
i purchased the nest doorbell battery and i can't get it to connect to the google home app the light does not turn blue it turns white when i plug it up and then turns green and flashes green what options can i take
EmptyNester
Silver Product Expert
The blinking green sounds correct to me.  Here is the video I used to get mine up and running and it worked for me.  I hope this helps:  Here is the link:
https://www.youtube.com/watch?v=19IFikX7w1w
