08-12-2024 10:05 PM
I have a wireless/battery doorbell. I purchased little Google speakers so that when someone pressed the doorbell it would sound a digital ding-dong through the digital speakers. It worked for the first 2-3 years we've had it. And it just stopped working recently: when the button is pushed, the ding-dong can be heard outside, but nothing comes through to the speakers inside so we don't know someone is at the door. I have gone on the app to try to change the settings, but it says that there can be no digital chime when a doorbell is not wired. However, that can't be because it has been working for us for YEARS.
Please help.
Thank you,
Brian
08-13-2024 07:11 AM
The "Indoor chime" option applies only to ringing an indoor doorbell chime, and is automatically disabled if your battery doorbell is not wired and connected to a transformer and to an indoor doorbell chime. Sending "visitor announcements" to your Nest Hubs and Nest Minis is controlled by the "Visitor announcements" option (https://support.google.com/googlenest/answer/7672451). I don't know why that option should suddenly quit working.
You could try contacting Support:
