03-01-2023 01:38 PM
My Chromecast plug is so annoying. It's too big to fit in behind my TV in the sockets there because it's too big for the gap. It also can't fit in the sockets behind my TV base units without having to move the units way out from the wall so the cable isn't bent and likely to break which looks so silly in the room. I've checked the tech specs and can't find what watt plug I need to get a less imposing plug for it. Anyone know what watt plug is needed or can recommend a substitute?
03-01-2023 04:41 PM
We use a grounding adapter like the one below at Home Depot for one of our Nest Hubs where the electrical outlet is crowded due to another adapter:
Or you could consider a short extension cord like the one below:
03-05-2023 10:00 PM
Hi Lynathche,
I hope we were able to answer your question with the info provided by @MplsCustomer . If you have additional questions, feel free to respond to this thread and we'd be happy to further assist you.
Muddi
03-11-2023 03:04 PM
Hey Lynathche,
I just wanted to check, do you have additional concerns or questions about your device?
Muddi
03-12-2023 04:55 PM
Hi Lynathche,
I haven’t heard back, so I'll be locking this thread if we won't hear from you in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
