ADT Thermostat Routine
Butch53
Just had two ADT thermostats installed. I can manually control them from Google Home but when I try to setup a routine nothing happens. I have been successful in automating a lightbulb to turn on at dusk and off at dawn. No luck with the thermostat change at 2 PM rising or 8 PM lowering.
Thanks.
Azarco
Hey Butch53,
That certainly hasn't been easy for you — let's check this out.
Are you using ready-made or custom routines? Are you getting any message when setting the routine? Also, can you still control your Thermostat using voice commands?
Could you try unlinking your ADT account to your Google Home app? Also, rebooting your devices might help too.
Alex
Princesss
Hi Butch53,
We just want to check if you have seen our response on the previous post? Let us know if you have additional questions, otherwise we'll be locking the thread.
Princess
Princesss
Hi Butch53,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google speakers and we'd be glad to assist you further.
Princess
