04-30-2025 04:04 PM
We have a Treatlife presence sensor and a Google audio speaker. I used the AI script generator on Google home web to create an automation. The automation does not have any errors. I have saved it and activated it. But it does not run when I select the arrow button to play the automation. I am logged into the same account as we used for the google home app. I have tried an automation that uses the sensor and the speaker without the condition, that works. I did the automation that works from the app on my iPhone. Any help is appreciated.
metadata:
name: Motion detected between 11:30PM & 2:30AM
description: Play a message when motion is detected
automations:
- starters:
- type: device.state.MotionDetection
device: Presence Sensor hallway - Loft
state: motionDetectionEventInProgress
is: true
# ---- CONDITIONS ---- #
condition:
type: time.between
after: 22:30
before: 02:30
# ---- ACTIONS ---- #
actions:
- type: assistant.command.Broadcast
devices:
- Loft speaker - Loft
message: Time to go to bed!
05-03-2025 03:21 PM
Hi @JeannieG!
Thank you for posting in the community. I can understand how important it is for you to get your Google Home automation working with your Treatlife presence sensor and Google audio speaker. I appreciate your efforts in creating the automation using the AI script generator on the Google Home website. I'm happy to help you!
I want to share with you the following articles that will help you with your home automation:
Let me know how it goes.
Geremi
