Advanced home automation (dimming lights)
Si
Hi
What I’d like to do using a voice command, is to say the command (e.g. watch a movie), for my WiFi lights to gradually dim. I get that I could do this manually, by adding a command like lights 99%, lights 98% etc, with a one second delay. However, I’ve got 4 WiFi bulbs in the room, so that’d mean I’d have to program over 800 commands (including light brightness and delays).
is there any easier way I can do this or achieve the same outcome?
thanks!
Juni
Hi Si,
Thanks for reaching out and for providing detailed information on your inquiry — these are of great help
Right now the only option is to create a routine where you need to add actions manually. We appreciate people who are keen on sharing their thoughts with us. We're always looking for ways to improve. I'd suggest you submit feedback about it, here's how.
Let us know if you have other questions and concerns otherwise, we will be locking this thread after 24 hours.
Juni
