01-26-2024 02:13 PM
The battery is dead.
dont charge and said battery issue contact google help
01-26-2024 03:02 PM
I can't tell whether you have a battery doorbell or a battery camera, but you can contact Support using the link and instructions in this post:
01-29-2024 05:59 AM
Hi all,
@XavierPP, I’m sorry to hear that you’re having trouble with the Nest device. I wanted to check if you still needed help. Were you able to contact our support team as suggested by MplsCustomer above? If yes, how was it?
If you haven’t done so already, to completely isolate the hardware issue, let´s factory reset the device. Follow the steps below:
Let me know how it goes.
Thanks for your help, MplsCustomer.
All the best,
Lance
