05-20-2024 02:21 AM
Changing Color via automation on the google home app has stopped working. I have tried to de-link - relink the apps but still doesn't fix the problem. Only works if the automation is manually triggered. Other commands like brightness/on-off work but not changing colors. I can manually change the colors through google home or voice. its only via automation.
Smart Bulbs that I am using is the Smartlife app, Tuya.
