Curtains not working as previously
Alaabustami
Hello…I’ve got the smart life app that I use to control the lights curtains etc….
this app is of course connected to the Google home app.
recently when I say open curtains the nest device replies with “sorry I didn’t understand "
I have to say switch on curtain for the curtain to open
previously everything used to work as normal
any idea what happend and how do I get it back as before??
thank you
25 REPLIES 25
Juni
Hi Alaabustami,
Sorry to hear about the trouble. I wanted to follow up and see if I could be of any help. A few things: were there any recent changes made before the issue started? Which Nest speaker? Could you check the my activity section in your Google Home app and check the command that got registered when it did not work? You can take a screenshot of it and send it to us. Check the details below.
Check your Google Assistant activity history
  1. Open the Google Home app .
  2. At the top right, tap your account.
  3. Tap My Activity .
Below are the steps on how to upload a photo:
  1. Start a new post.
  2. Click Insert Image.
  3. Choose an image source location.
  4. Follow the on-screen instructions
Also, you can tap the "Drag and Drop" option. Maximum attachment is 5 MB.
Juni
Alaabustami
thank you for your reply...
no changes had been made prior to the problem.... the nest speakers are the nest mini and google nest hub.
this is when it was workingthis is when it was workingthis is when it started saying it is not supportedthis is when it started saying it is not supported3.jpgthis is after unlinking smart life and relinking it again againthis is after unlinking smart life and relinking it again again
Juni
Thanks for the response. To further isolate the issue, create a new home and move your Nest Mini and Nest Hub there then unlink your curtains from the current home and relink it to the new one. Check this helpful link.
Keep me posted.
Juni
Alaabustami
i tried it and it didnt work what i also noticed was this....when i clicked on the curtain ......it didnt give me the option of open and close..
Juni
Hi Alaabustami
Buzzing in — do you still need our help? Don't hesitate to reach back if you do.
Juni
Alaabustami
hey juni
I will try what you said last and update you on what happens…hope it works..,fingers crossed!
thank you
alaa
Princesss
Hi Alaabustami,
Thanks for updating us. Glad to know that it's now working. I'll keep this thread open for 3 more days so you can monitor its behavior and update this thread.
Princess
Hello princess
I still have tried it to see if it works… please keep the thread open the problem hasn’t been resolved yet.
thank you
alaa
Princesss
Hi Alaabustami,
Chiming in-- have you noticed any changes on its behavior for the past 3 days? Let us know so we can check what's the best steps to try.
Princess
Alaabustami
I’ve tried what u said and it still hasn’t worked
Alaabustami
 i noticed this as well....when i click on the curtain device.....i cant open and close it
Princesss
Hi Alaabustami,
Thanks for trying the steps. Can you confirm if there are other home automation devices connected to your Google Nest speakers? Are they working good?
Princess
Yes all is working perfectly…except the curtains
Yes all is working perfectly except the curtain
Princesss
Hi Alaabustami,
Thanks for clarifying. Have you already contacted the manufacturer of your automated curtains?
Princess
Princesss
Hi Alaabustami,
Princess
Yes I have contacted him…the smart life automated home app is working perfectly…he said it has to do with the Google home app and he doesn’t know the solution
Princesss
Hi Alaabustami,
Thanks for the update. Could you please provide any screenshot of what you see every time you link your curtains? Also, is it possible for you to try a different phone to see if this would make any changes.
Princess
Hello…. I’ve done that in a previous post…the only difference is that now it doesn’t even work even if I say switch on curtain…I’m not using phones…. I use the voice recognition on the devices
Princesss
Hi Alaabustami,
Thanks for the additional info. Can you try to command the Google Assistant on your phone to control the curtain and see if you will also get the same response?
Princess
Princesss
Chiming in-- have you ahd the chance to try the suggested steps posted above? Let us know if it works, otherwise we'll be locking the thread shortly.
Princess
Princesss
Princess
Alaabustami
Yes same thing….sometimes it replies to switch on curtain…sometimes it doesn’t
Princesss
Hi Alaabustami,
Thanks for trying the steps. If it happens to do the same when you command your Google Assistant from your phone and Google Nest speakers, it might be isolated to its integration. However, other home automation devices are working so we can't speculate that the issue is within the Google Nest devices. Please make sure that the curtains are up to date and it's best to reach out to the manufacturer to check with them their integration with Google.
Keep us posted.
Princess
Princesss
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Nest speakers and we'd be glad to assist you further.
Princess
