Extend 2 x WiFi signals
allanb
I have two routers setup with WiFi in my living room. One is the regular ISP internet connection (SSID SISP), the other is a VPN connection setup through the ISP router (SSID SVPN). Neither WiFi reaches the other end of my apartment. What's the best way to extend both WiFi signals to the other end of my apartment? Can Google Nest be setup to transmit both WiFi connections?
Juni
Hi allanb,
Good question. Let me answer your inquiry. The Nest Wifi router can cover up to 2,200 sq. ft. It cannot transmit two WiFi connections at the same time. You can check this helpful link to get more information about our Nest WIFi devices.
Tech specs for Nest Wifi Pro, Nest Wifi, and Google Wifi
Keep me posted.
Juni
Azarco
Checking back in if the information shared above helps. Let us know by updating this thread and the Community will be happy to lend a hand.
Thanks for the help, Juni!
Alex
Azarco
Hello allanb,
I want to ensure you are good to go, and everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
Alex
