Google Home Mini not running routines
shadingle
Hey there! Up until about 2 weeks ago my home routines are no longer running on my google home mini. I have tried disabling and then enabling the routine, un plug and plug back in, asking the routine to start via voice or through the app, and reset the mini. Nothing is working however. The mini is still listening to me and answering me for anything other than my routines and I do not know how to fix it
8 REPLIES 8
mikkies
Living in Australia has taught me to find pleasure in the little things - good coffee, an evening breeze or just silence. I discovered https://lesalonmelbourne.com/en-au/ unexpectedly when I was looking for some light entertainment after work. Everything is simple and transparent, no complications. A couple of rounds - and you already feel how you relax. A pleasant way to distract yourself and reboot.
• No voice trigger automations are working?
You don't have any other Google speaker to test out the automations?
Or you could use:
1. The Google Assistant on an Android phone
2. The Assistant app on an Android phone
3. The Assistant tile in the Google Home app
**bleep** if only I had an android but everything I own is Apple.
liam788fh
First, ensure that the device is connected to the internet and linked to the correct Google account. Open the Google Home app and check if the routines are properly set up and activated. Also, verify that the trigger phrase or scheduled time for the routine is correct. Sometimes, outdated firmware or a recent update can disrupt routine functionality of Noob win—restarting the device or updating the app might help. If the problem persists, try deleting and recreating the routine. For more persistent issues, a factory reset may be required to restore proper functionality.
Hey unfortunately everything you suggested I have already done and it still won’t run routines
vicentteenglish
Hey! Thanks for sharing—sounds like you’ve already done all the right troubleshooting steps. It’s great that your Mini is still responsive otherwise! Since routines specifically are the issue, it might be worth checking if there’s been a recent app update or bug affecting them. You could also try setting up a completely new routine to see if that triggers things back to normal. Hopefully, it’s just a temporary glitch and gets sorted out soon!
Thanks for the suggestions! Unfortunately I did both of those as well and it still won’t start the routine.
Ryaomez
Hej, alla. Jag är en försiktig person och gillar inte att ta stora risker, så jag är ganska avslappnad när det gäller onlinekasinon. Jag provade game chicken road på min lediga dag när jag hade lite tid över. Först spelade jag på miniminivån bara för att förstå mekaniken. Jag gillade att ingen stressade mig och att allt berodde helt på mig själv. Ibland slutade jag medvetet tidigt, ibland fortsatte jag längre. En kväll blev särskilt framgångsrik. Halvvägs in insåg jag att jag skulle rekommendera detta spel till dem som gillar att ha kontroll över situationen. Mina intryck är positiva och spelet lämnar en behaglig eftersmak. Sammanfattningsvis skulle jag helt enkelt säga – jag rekommenderar det.
