07-19-2023 08:17 PM
My Google Nest Hub Max keeps changing status from away to home even though I'm away (by touch control) and has to be changed manually back to away. Please advise.
07-26-2023 02:16 PM
Hi Maia1,
Thanks for reaching out. When did it begin? Were there any recent changes made prior to the issue starting? Do you have other home members added and are you using the home away feature? Also, what steps have you taken so far?
Try to disable and enable phone location for presence sensing and observe if it makes a difference. Check out the steps below:
Learn how to use your phone location for better presence sensing.
Juni
07-26-2023 06:50 PM
Hi, it had happen on my Google Max Hub 6 minutes ago. I'm atm 11 km away from home. I have done the above stated amd even removed and factory reset it few times, no progress. I've noticed that around that time when I'm at home, it restart and the screen shows restarting but since I'm at home, nothing changes. Whereas if I'm away, like today, it changes to home regardless of not being at home. Presence sensing has been updated numerous times. Doesn't help. Please advise
07-27-2023 08:22 AM
Furthermore ,I'm themanager and the only member in this home
09-29-2023 11:50 AM
Hello Maia1,
Apologies for the delay. Could you provide your Google Nest Hub Max's cast firmware version?
To check which firmware version you're on, follow these steps:
We look forward to your response.
Princess
