08-04-2023 07:32 PM
On 8/4/23, Google Home is no longer able to control all Philips Hue lights (Philips Hue Bridge). The Google Home app shows all lights as offline. All google devices advise unable to connect to Philips Hue.
Apple HomeKit devices continue to be able to control the lights, without issue.
Philips Hue app controls the lights as normal, without issue. I have reset network & Hue bridge. I have also submitted this through the Google Home feedback.
Thank you.
08-09-2023 02:30 PM
Hi MarkG3,
Thanks for reaching out. I know how it feels when something isn’t working as it should. Have you recently made any adjustments to your WiFi network, Google Home, and/or Philips Hue setup? Try the steps below in order and let us know the result by updating this thread:
Kimy
08-15-2023 12:03 PM
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
08-19-2023 01:35 PM
I was able to remove and re-add Hue and that seems to have fixed the problem.
08-22-2023 11:30 AM
Hey MarkG3,
We’re glad to hear that it’s already sorted out! If you have other questions or concerns on Google Home/Nest devices, you know where to find us. We’ll be more than happy to assist you.
Alex
05-05-2024 11:50 PM
I have the same problem. Did everything, also new accounts, new bridge, modem wifi, deco wifi. Nothing seems to work. Also try new matters protocol. This will add the bulbs but with no name / room and all lights are offline. If I reconnect the philips hue to google home it say somethings wrong. Philips updated their firemware on 28/4 and 2/5 on their bridge. Something seems wrong. Because if I add philips hue to IFTT it works seamlessly....
