Help with heat while meat is charging
JW29
Is there a way to turn the heat on manually while the best unit is charging with a cord connection?
Hello JW29,
It's nice to see you here posting in the Google Nest Community. I'd be happy to shed some light on the situation here!
While your Nest Thermostat is charging with a cord connection, you won't be able to manually adjust the temperature to turn the heat on. The charging process would interfere with the thermostat's ability to control your HVAC system if you pulled out its display from its base.
To confirm, what country are you posting from, and what type of Nest Thermostat do you have?
Warm regards,
