I think I need to factory reset
d8109996
I changed Internet provider so no longer connected to wifi I originally used to set up my nest speaker. I am told to factory reset but I need the wifi information that no longer exists
2 REPLIES 2
GBD
You shouldn't need to connect to the speaker via Wi-Fi to factory reset it. Remove the device from your google home and then follow the instructions here to factory reset.
https://support.google.com/googlenest/answer/7073477?hl=en#zippy=%2Cgoogle-nest-audio
Charisma1982
Factory reset
