02-22-2023 02:49 AM
1. I cast a YouTube video from a smartphone to a Nest Hub 2nd Gen, and lower the volume to 1 on the Hub
2. then the casting gets interrupted
3. when I re-cast, the volume on the hub goes back to whatever the cast volume on the smartphone is. It should
You can always increase volume, but if you had it turned low for a reason, you can't undo unintentional loud volume.
04-04-2023 06:04 PM
Hi 111001010101111,
This is not the experience we want you to have, let me help you. A few questions: when did your issue begin? Were there any recent changes made? What phone are you using, iOS or Android?
It would help a lot if you could do a sequential reboot first:
Once done, kindly set the volume of your Nest Hub 2nd Gen to 5 before casting from your phone. See the difference and tell me how it goes.
Dan
04-07-2023 06:29 PM
I want to check if you have additional questions and concerns about your device. Let us know by updating this thread, and we're glad to assist you further.
Juni
04-08-2023 06:38 PM
Hi 111001010101111,
Dan
