01-08-2025 11:32 PM - edited 01-08-2025 11:32 PM
Hello! I am hoping to control my HVAC’s fan through an automated script via GoogleHome. From the research I’ve done, there’s not a way to control the fan via automations.
Here’s what I want to script:
If BASEMENT_TEMP > 85
then FAN_ON
else FAN_OFF
Let me know if anyone has had any success controlling their fan via automations.
thanks.
01-10-2025 01:06 PM
Have you tried using IFTTT?
01-15-2025 11:55 PM
Hi @Eco_Heat_MtnMan,
Thanks for reaching out to the Google Nest Community. I can understand how important it is for you to create a fan control automation in your Google Home. Don’t worry; help is here.
I want to share with you the following articles that will help you with your home automation: Create advanced home automations with the script editor. Write scripted automations with the script editor.
Let me know how it goes.
Derick.
08-20-2025 03:21 PM
The usual "non-answer". We need a scripting command to control the fan. I'm about ready to buy ecobee cuz this is plain stupid.
10-16-2025 03:10 PM
No, there's not. I'm currently controlling mine through Nest Smart Device Management API. But seems that Google is in the process of slowly killing that too. I tried Google Home automations for temperature control (beyond the constant manual adjustments the thermostat requires), but I found them to be extremely unstable and unreliable. So you may be right with your backout plan, as there may be no permanent option to fully automate Nest thermostats.
