07-14-2024 06:41 AM
I've had an automation for quite a while now (I think a year or two) that turns off all the lights in my home, pauses all my media play (on Sonos and TV) and resets the volume on each of my Sonos speakers to 15%. This worked just fine up until very recently, when it stopped resetting the volume for no reason (although the rest of the automation still works).
I originally created the automation in the iOS Google Home app before scripting was available. When it stopped working, I tried to recreate the automation through scripting (and I've successfully created many other scripted automations, so I don't believe this is a scripting error). The rest of the script works (turning off all of the lights, etc.) but the automation will now only set the volume of one device (regardless if I try to change the volume of all devices using a single command and multiple device names, or if I use a separate command for each device).
I'm assuming this is all still fallout from the Google/Sonos lawsuit, but does anyone have advice or suggestions? There must've been some coding changes at Google or Sonos recently, because this did work until sometime in the last couple of weeks...
Thanks!
