01-23-2023 12:56 AM
This started a few days ago after a year + of working fine. As long as I have this particular Nest Hub Max plugged in, it hijacks the audio from my Home Group and only plays audio on this one device - specifically for one app: Smart Audiobook Player. Updating the app made it work like normal again - once. And then right back to hijacking the audio from the group.
I only have Nest products in the group: 2 Nest Hub Max and 5 Nest Audio. I factory reset the Next Hub Max causubg the issue (Office display) to no avail. I'm using a Samsung Galaxy S22 Ultra. My software and all my apps are up to date. Any ideas?
01-27-2023 01:40 PM
Hi Glenn3,
Thanks for reaching out and for providing detailed information on your issue and the steps that you've done — these are of great help!
Could you check if your Nest Hub Max is set up as a default device to play the audio? Below are the steps to view this setting.
Check this link for more information.
Hope this helps.
Juni
01-30-2023 08:45 PM
Juni,
Thank you for your reply. Unfortunately, this didn't help. My audio will only play to the office display when I select my home group. If I unplug the office display, it will only play to the kitchen display when I choose the home group. It's very frustrating as this is the primary purpose of my using these devices.
