Strange Behavior with My Nest Thermostat After Update — Help Needed
samAndrew
Hi everyone — I’ve noticed something odd since the recent firmware update on my Nest Learning Thermostat (3rd gen). It now randomly changes modes (heat/cool) even though my schedule hasn’t changed. I’ve tried rebooting the thermostat and restarting the router, but the issue persists.
Has anyone else experienced this?
  • What troubleshooting steps did you take?
  • Did you end up contacting support?
  • Or was it a firmware bug that got fixed in a later update?
Thanks in advance—any advice would be super helpful!
ByronP
Hi samAndrew,
Thank you for reaching out to the community. I see you're experiencing trouble with your Nest Learning Thermostat (3rd gen), which is randomly activating (heating or cooling) unexpectedly after the update, even though you haven’t made any schedule changes in the Nest app. I appreciate all the troubleshooting steps you’ve already taken. I’m here to help.
To assist you better, please answer the following questions:
  • When did the situation start?
  • What other strange symptoms have you experienced since the situation began?
  • Are there any error messages? If so, what are they exactly?
  • What kind of HVAC system do you have (Heat pump, conventional system, etc.)?
  • Do you notice any intervals or specific patterns between these strange behaviors?
  • When was the last maintenance check for your HVAC system?
  • Has there been any recent changes or upgrades to your HVAC system?
  • Have you experienced any power outages within the last few days or weeks?
Please keep me posted on your findings.
Byron
