4 weeks ago
I’ve added a Matter temperature sensor device to my setup.
I’m using a Google Nest Hub (2nd Gen) as the border router.
The temperature value from my device is displayed correctly on the Nest Hub’s LCM screen, but the unit (°C / °F) is missing.
My device supports switching between Celsius and Fahrenheit, but the Nest Hub only shows the numeric value without any unit indicator.
This can be confusing for users since they can’t tell which temperature scale is currently used.
Is there any way to make the Nest Hub display the temperature unit, or is this currently a limitation ?
3 weeks ago - last edited 3 weeks ago
Hi @Emma-1003,
Thanks for contacting the Google Nest Community. I understand you're trying to change the temperature unit between Celsius and Fahrenheit on your Nest Hub. I also see that the device is only showing a numeric value without the C or F indicator. I'm glad to help you.
To troubleshoot the issue further, please try the following steps in order:
Feel free to keep posting if you have more questions.
Gabriela
