01-29-2023 04:09 AM
Hi. I have a Nest wifi router and 3 wifi points, but still a weak signal in some areas at home.
According to Google, my 2 Nest Hubs (gen2) are Thread Border Routers.
How can I use the nest hubs to improve my nest wifi mesh network ?
I was hoping the Nest hub will automatically become part of the Nest Wifi mesh using Thread.
Is there a way to monitor which items are connected using Thread ?
appreciate any help.
02-13-2023 05:02 PM - edited 02-13-2023 05:05 PM
Hi Quikmark2,
Thanks for reaching out.
You might find these info helpful on setting up your Nest Wifi points:
You can quickly set up Nest Wifi Pro and manage it in the Google Home app along with your other connected devices. If you already have a Nest Wifi or Google Wifi system, to set up Nest Wifi Pro you'll have to remove the previous network from your Google Home structure, or set up a different Google Home structure. After the new network is set up, automatic updates to Nest Wifi Pro will give you new features and help keep your network secure.
Nest Wifi Pro uses network insights to automatically optimize your network's performance. For example, it'll automatically prioritize video calls to help keep them smooth and consistent. Nest Wifi Pro can also adapt and account for when your internet service provider (ISP)'s speeds dip unexpectedly.
Wi-Fi issues are proactively scanned for and diagnosed, and Nest Wifi Pro can even fix common network problems on its own so you don't need to. It'll let your know if a simple fix, such as a new Ethernet cable, can improve your network's performance.
You can create a guest network and share your password from the Google Home app. You can also decide which devices to prioritize for faster speeds, and run speed tests to understand the performance of your network and device connectivity.
Family Wi-Fi lets you set schedules to manage screen time, restrict certain kinds of adult content, and pause Wi-Fi for specific devices whenever you want.
Hope this helps.
Princess
02-17-2023 04:35 PM
Hi Quikmark2,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Nest devices and we'd be glad to assist you further.
Princess
02-16-2023 04:05 PM
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
02-18-2023 11:01 AM
Ok thanks for the answer. Not 100% an answer to my question but thank you anyway.
you can close the topic
02-21-2023 10:44 AM
Hello Quikmark2,
Sure thing! We'll mark this as complete and lock this thread now. If you have other questions or concerns with your Google Nest devices, don't hesitate to open a new thread and the Community would be glad to assist you.
Kind regards,
Alex
