01-09-2024 04:33 AM
I have a question about the web interface.
I have 6 nest cameras with constant power and I have a nest doorbell battery.
In the google home web interface it is possible to see a live feed from the cameras which is nice.
Since I have that number of cameras, I cannot see them all on my screen at once, which is what I want.
My questions is then;
1. Is it possible to resize the camera feeds of the individual cameras to my liking? e.g. I don't need my doorbell feed to be as large as it is, so I would like to resize it to make it smaller
2. Is it possible to rearrange the feeds to my liking? e.g. I would like to move the doorbell feed to the end, and have feeds of my door and driveway as the first feeds.
3. [NOTE: this is a nice-to-have and not a need-to-have] I saw another post in here where a member asked if it would be possible to have a feed "pop out" or getting larger if movement was detected. e.g. If all camera feeds are the same size, and movement is detected in the driveway, the driveway feed enlarges to indicate movement.
01-14-2024 02:24 PM
Hi CVI89DK,
Thanks for reaching out and sharing your thoughts with the Community. I’d be happy to help you with your questions. Let’s check them out.
While it isn’t possible to resize the camera feed, rearrange them, or have the feed “pop-out” if movement was detected, here are the things that you can do at this time.
If you have more than one Nest camera, you can choose how to view your cameras on your browser screen.
To save power, the live video stream will stop automatically:
To start the live stream again, tap Watch live.
When you first sign into Google Home for web, the screen shows you the live feed of all the Nest cameras in your home.
For each camera on the screen, you can also view:
To control a single camera:
To turn all cameras on or off:
Also, our dedicated team is committed to providing our users with an exceptional experience. Your input is invaluable, so we kindly request that you share your feedback about Google Nest with us. Additionally, we encourage you to stay connected with the Google Nest Community page for updates.
Reach out if you have any other questions.
All the best,
Lance
01-16-2024 05:47 AM
Hi Lance,
Thank you for the reply.
I am well aware that I can choose how to view the camera feeds, but since I have 5 cameras and a doorbell currently, it does not all fit in my screen at once, so I wanted to be able to rearrange the camera feeds so I would be able to see the ones I find most relevant.
01-16-2024 12:49 PM
Hello CVI89DK,
I appreciate your response. While rearranging camera feeds is not currently an option, our team is committed to ensuring an exceptional user experience. Your feedback is highly valuable, and we kindly ask that you share your thoughts about Google Nest with us.
Lance
03-03-2024 03:28 PM
I do not have any of those options in the upper right corner when viewing my cameras on the website. Mychoices are 3 vertical dots which turn the cameras on or off and in very uppermost right corner 3 more vertical dots for help, send feedback or About Google Home. That's it. I woulld really like to rearrange mycameras. I have 4 cameras and instead of 3 on top ot the other 2 I have 3 across on top and one below, greatly limiting their size on my screen.
03-08-2024 07:56 AM
Thanks for chiming in, Lance.
@muskyboy, if you're using the Google Home app on the website, the options mentioned above may not be available in that specific interface. The options described are typically found in the mobile app version of Google Home. To rearrange your cameras in the Google Home app on the website, you can try the following steps:
If you don't see any options to rearrange the cameras within the Google Home app on the website, it's possible that the feature may not be available in that version of the app. In that case, you may need to use the mobile app version of Google Home to rearrange your cameras.
Let us know if that helps.
3 weeks ago
Any developments on this request/proposal? I would LOVE to be able to resize my nest cam feeds to all fit on one screen. You'd think it would be easier to implement considering users can reorder them... Why not be able to resize them, too? My doorbell cam feed is huge, too, meaning I have to order it after any others that I might want to try to see two at a time. Seeing 4, or even 6, at a time, seems like it shouldn't be too difficult, considering the complexity of everything else involved.
