02-12-2024 05:19 PM
I own a Nest Pro router and point, as well as a Google Wifi point/router. The Google Wifi is connected to my PC by a Cat6 ethernet cable. My apartment is no more than 900 square feet and my internet plan is of 300mbps. The Nest Pro router is in the middle of the apartment in the living room, the Nest Pro point is across the wall on the other side in my bedroom and the Google Wifi router/point is in the same room by my PC. All up to today, my Nest Pro point was showing good connection and my Google Wifi point was showing great connection. I decided to move the Nest pro point on my dresser, still in my bedroom, but when it turned on again, all the connections started showing as weak. Then, I decided to put it back where it was, right next to my bed, it turned on again, and again it showed weak signal. I factory reset every single point and router as well as my Wifi modem, and still everything is showing weak signal. What the heck happened? Why is now everything all of a sudden "weak"?
