10-09-2022 06:38 AM
My google hub nest max stop responding to hey google commands. I have followed all the tips on the internet and nothing has solved the problem. If I unplug the device to reboot it, the command works for the first command and then does not respond after that saying something went wrong?? Any help would be appreciated.
10-12-2022 01:06 PM
Hi tcdixon,
Thanks for posting.
To narrow things down, what is the command/question that you gave? When did this start happening? How often does it happen in a day?
While we’re at it give these steps a try:
You can also select the Controls tab next to History to access the recording. Make sure you select "Include voice and audio activity".
Keep me posted.
Dan
10-16-2022 08:51 AM
Checking back in to see if the troubleshooting shared above helps. Let us know by updating this thread, and the Community will be happy to lend a hand.
Alex
10-17-2022 10:37 AM
Hello tcdixon,
We want to ensure you are good to go, and everything is working properly. Please let us know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
Alex
10-17-2022 04:35 PM
Hey Dan
I have not had a chance to do all the steps you have asked yet, however what I can tell you is when I reboot the hub and it reloads I can say "Hey Google play Spotify". and it will acknowledge and play. A few minutes late I can say "Hey Google turn it up" and the colours in the top left corner move like it is hearing you but a few seconds later the hub says " something went wrong please try again later. When I try again later the same message occurs. When I reboot the same thing happens again it works perfect for first command then after that it does not work?? This started happening about a month ago and before that anyone could give commands to the hub ( my wife, my grandkids ect.) and it would always work?? Even now I say Hey Google and it says something went wrong please try again later. My hub is not even two years old.
Terry
10-17-2022 04:46 PM
That certainly hasn't been easy for you. Have you tried resetting your Nest Hub Max? Could you provide us the cast firmware and software version of your display?
Alex
10-17-2022 04:47 PM
Hi Alex
Where can I find that information?
Terry
10-18-2022 12:07 PM
Hey everyone,
@tcdixon, here's the steps on how to get the cast firmware version of your Google Nest speakers.
To check which firmware version you're on, follow these steps:
@Shutupalexa, to reset your device, you can follow the steps on this link. Let us know how it goes.
Princess
10-18-2022 06:07 PM
Hello Princess
So I have reset the hub using the link you provided and I went through all the steps to set up the hub again and for now our commands seem to be working. I will keep you posted over the next day or two to see if they remain working.
Thanks
Terry
10-21-2022 09:17 AM
Hi tcdixon,
Glad to hear that this has been sorted out and thanks for sharing your resolution in the Community. Let me know if you have other questions and concerns. We're here to help.
Dan
10-24-2022 05:40 PM
I appreciate the help, everyone.
Archie
10-18-2022 02:16 AM
Could you perhaps explain the steps to reset the device?
10-18-2022 05:39 PM
Alex
The cast firmware is 1.62.312297 and the system firmware is 7.20220419.2.164
Terry
