11-29-2021 01:26 PM
We live in CO and own a 2nd property in IL. Can we monitor/adjust all nest products in the rental home through Google Home from this distance?
12-01-2021 08:13 PM
If i understand your question...of course!
Do you already own the Nest products? Are you buying new? The newer Nest products only use Google Home whereas the older ones require the Nest app, but can be integrated into Google Home. Regardless if the device is integrated into Google Home you should be set.
It would probably be best to have Google Home setup with two homes - one for your 2nd property and 1 for your primary residence. In the Google Home app, change homes depending on which you want to control. Everything that appears in Google Home can be controlled from anywhere that you have internet access.
Does that help, or am I misunderstanding?
12-06-2021 09:55 AM
Just wanted to jump in here to check to make sure that you saw the response from sporfrog. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Have a great day.
Garrett DS
12-07-2021 10:22 AM
Have a great day,
Garrett DS
