01-03-2022 07:42 PM
Nest thermostat won't bring temp up to setting I want when we are away. This is a vacation home and in the winter I would like to keep the temp higher than 45 degrees. No matter how high I set the temp from my phone it will not bring to temp. Seemed to work fine over the weekend while we were there but once we are away I cannot set temp.
01-03-2022 09:55 PM
It may be to do with the home/away settings. If you’re controlling with your phone you can tell it not to work with your phone’s location. If you check the settings on the app on the front screen under home/away assist and then under the next screen where you can actually change temp it may help. You can also set the eco/safety temps to suit your requirements. Hope that helps
01-04-2022 12:12 PM
