06-15-2024 01:45 PM
Installed a Google Nest thermostat in the winter after the one that I had failed. Install and setup where very easy. During the winter months it worked perfectly. Once it started warming up and needing cooling in the house I noticed that my fan will not stay at a single speed, fan fluctuates during the cooling process. When it gets close to shutting off the fan slows down so much it sounds like it is going to shut off than ramps right back up to full speed or a half speed. Did I miss something during setup. Forced air furnace, 2 stage heat with air conditioning. When I run the self tests for the heat/cool settings, there is no errors reported.
06-18-2024 02:40 PM
Hi @jparker01,
Thanks for posting here in the community! I'm sorry to hear that the fan doesn't stay at a single stage. I'm happy to help you find a solution for your thermostat.
To better assist you, I'd like to ask a few questions:
In the meantime, I suggest following these troubleshooting steps:
Please keep me posted.
Ana.
