12-14-2023 08:50 AM
We are getting an intermittent E74 error during heating. The heater will come on for 5, 10 or 15 mins, but doesn't reach the programmed temperature, then turns off and the E74 code is generated. It will then come on again after a little while, but stops again with the same error. It will go through this cycle until it eventually reaches the programmed temperature. During the summer, when using the AC, we didn't have any issues. The issues didn't start until fall when we switched over to heating. Based on other threads for this issue I've looked at the wiring and I didn't see anything that jumped out at me there as being an issue. I also looked at the drain pan for the furnace and didn't see any standing water and also looked at the furnace drain pipes and didn't see any clogging. Just wondering if anyone else had a similar issue and found the fix. Thanks!
12-18-2023 12:40 PM
Hi JBussi,
Uh-oh! I'm sorry to hear that your thermostat is not reaching the programmed temperature, then turns off and the E74 code is generated. Check on the following:
It is worth noting that you turn off the power to your HVAC system when you are about to touch some wires on your thermostat base. If you are not comfortable checking on the following, consider contacting a pro.
Let us know how it goes.
