07-16-2024 07:45 PM
My nest learning thermostat has suddenly started cooling well beyond the set temperature. It is causing my house to feel like a refrigerator, and I have to constantly intervene with its functioning throughout the day and night.
I have a Google Nest learning thermostat 3rd generation, and 3 Google Nest temperature sensors placed at specific locations in my house. I have the learning option turned off, and a schedule set to read the different sensors at different points in the day. This has worked fine for several months, but suddenly over the last few days the system will keep cooling to several degrees below the set temperature, and I have to switch to a different sensor to basically resest the thermostat so it understands it has cooled beyond the set temperature and then will turn off. I have had it set to 73 and it was still cooling even though the sensor it was assigned to was reading 70.
The thermostat is several years old, and the sensors are a few months old. I have checked the connection on all sensors, they are all connected and the temperature readings update just fine. The HVAC cooling system works fine and was cleaned this spring.
How can I fix this issue? I know it's not normal behavior because I've had the thermostat for years, and the sensors worked perfectly for regulating the temperature up until a few days ago. The temperature outside did not dramatically change over the last few days either.
07-19-2024 08:48 PM
Hi A_lec,
Thanks for reaching out to the Community. I am sorry that you are having issues with your Thermostat cooling mode, I’d be happy to help you. Let’s check it out.
A Nest Learning Thermostat cooling excessively can be uncomfortable and lead to higher energy bills. Since you've already tried the basic troubleshooting steps and before we get started with further details, let me ask you some important questions:
Here are some steps you can try to troubleshoot the issue:
1. Check the Nest App and Thermostat Settings:
2. Heating and Cooling System:
You can also check the following article to Troubleshoot issues with the Nest Temperature Sensor.
Let me know how it goes.
Mario
