11-22-2023 12:42 PM
My Nest sensor keeps going offline. I replaced the battery and removed and readded the sensor getting a successful connection. However, within 24 hours the sensor reads offline. This has happened multiple times. I need help.
11-26-2023 08:24 AM
Hi PatrickG2,
Yikes! I'm sorry to hear that your thermostat keeps going offline. A few questions:
i'll look forward to your response.
11-26-2023 08:58 AM
You probably need to contact your HVAC company because it sounds like the main power to your thermostat from the HVAC unit is intermittent. Your NEST program forgets settings if the main power is off too long and the little battery drains below normal.
12-01-2023 08:26 AM
Hi all,
Thanks for chiming in, @HalKunnen.
@PatrickG2, I want to check if you managed to see the response above. Please let us know if you still have questions or concerns, as we'll be willing to assist you more.
12-01-2023 08:31 AM
Yes, I have completed these steps. I did remove and reconnect my sensor once again, but once again it was offline the next day. I have since tried to reconnect but was unsuccessful. This is annoying and inconvenient because the sensor is in our basement TV room where we spend a lot of time.
What is your advice?
12-01-2023 08:35 AM
I have had no other problems with my Nest thermostat nor with anything connected to it. We have had no recent power outages.
I replaced the sensor battery and it reads strong on my battery tester.
12-08-2023 06:43 AM
Gotcha. Follow these steps (skip the ones you already did):
Let us know how it goes.
12-09-2023 04:40 PM
Hey Zoe. Thanks for your suggestions.
I have unpaired my sensor multiple times and reset exactly as you describe.
It will pair
, but within 24 hours it's offline. In that interval I have not used it to set the temperature.
Is there a way other than you suggest?
12-09-2023 06:38 PM
Are you able to verify that the power supplied by your HVAC is connected 24/7? Mine lost connection like this because construction workers turned the breaker off and the NEST battery lost charge. NEST memory resets to factory settings when power is lost. I’ll bet you have a power problem. Too bad NEST didn’t program their system to accommodate memorizing user settings.
12-10-2023 02:35 PM
Hi all,
@PatrickG2, thanks for letting me know. Don't give up on us yet—we'd like to further check on this. Could you fill out this form and let me know once you're done?
12-17-2023 02:36 PM
Hi there PatrickG2,
We've received your form—thanks for filling that out. Please keep an eye on your email, as someone from our team will reach out to you to assist you more. If you have questions or concerns in the future, feel free to start a new thread, and we'll be happy to help.
