07-10-2024 08:46 PM - edited 07-11-2024 11:43 PM
Installed a brand new 3rd Gen learning thermostat. All tests run fine except second stage cooling. My AC just groans and stalls and never gets going.
Have a two stage AC and gas furnace, about 20 yr old Bryant models. Re: wiring I have originally Rh with jumper to Rc, G, W, Y, and Y2 (blue wire). I plugged the wires into the same corresponding terminals for the thermostat: Rh, G, W1, Y1, Y2 (again, blue).
First had to figure out that my first 3rd Gen thermostat had a bad battery. So I'm on my second Nest in three weeks. At least this battery is fine.
07-14-2024 10:57 AM
Hi LewisWilliams,
Thanks for posting in the community! Sorry to hear that the second stage cooling isn't kicking on in your Nest Thermostat. No worries, help is here! Here you have some recommendations that might help to fix this:
Let me know how it goes.
Axel.
07-10-2024 08:56 PM
Sorry not sure how to post photos. Here are links to the before and after.
https://www.flickr.com/photos/41605477@N04/53849350033/in/dateposted-public/
https://www.flickr.com/photos/41605477@N04/53849529190/in/dateposted-public/
07-10-2024 10:12 PM
Here's the power info:
07-13-2024 07:23 AM
Hi anyone have suggestions?
07-14-2024 10:57 AM
Hi LewisWilliams,
Axel.
07-17-2024 07:56 AM
Thanks for the info! I am first having an HVAC repair person take a look at the system. Will report what I discover.
