02-18-2023 01:23 AM
I purchased Google wifi about 1 month ago. We have a 1,150 sq ft apartment. My google router(pod) is on top of a shelf (about 5ft 9in off the ground) in living room. Google wifi pod(looks the same as router) is in our guest bedroom towards the back of the apartment. It’s on a shelf about 3ft off the ground. Living room router speed stays around 55-85mgps & is wired. Guest bedroom wifi pod is also wired, but speed is consistently above 200mgps. Mesh test says great connection every single time.
why is there such a vast difference in speeds? I’ve reset both, called a google rep, restarted the entire system, and nothing seems to work which is disappointing for a $70 1 gig wifi service
02-21-2023 07:05 PM
Hello Aj400,
Thanks for posting. I'm sorry to hear you're having this issue. You mentioned that you spoke with our Google support. Could you provide the case ID number of your interaction so I can check for you? I'll wait for your update.
Abi
02-25-2023 10:13 PM
Hey Aj400,
Abi
02-25-2023 10:16 PM
Hi Abagail,
just saw your response. Where would I find the case ID #?
02-26-2023 08:00 PM
Hi Aj400,
You can see the case ID number in the email sent to you by our Google support team. I'll wait for your update.
Abi
03-01-2023 08:54 PM
Hey again Aj400,
We’d like to check in again in case you have any further questions or concerns. Feel free to reply to this thread and we’ll help you out.
Abi
03-04-2023 01:11 PM
Hello Aj400,
It's been a few days since your last reply — we're going to lock the thread within 24 hours. If you have further concerns, please feel free to create a new post.
Lovely
03-04-2023 01:15 PM
my service is running great as of the last few days. Not sure why, as I didn’t change anything on my end. iPhone 13 Pro Max getting download speeds from 130-440 mbps depending on where I’m at in the house. Thanks for the help anyways!
03-04-2023 03:08 PM
Hi again Aj400,
No biggie! I appreciate your update and I'm glad that everything's going well on your end. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Lovely
