12-10-2022 12:03 PM
I have a Synology Nas on my network that I access from both inside and outside my Lan depending on where I am. I use a domain address (boxname.synology.xxx.me) with port forwarding set in my google pro router. When I am inside my Lan using Nat loopback (also called Nat hairpin) I can access the NAS using the DN address.
The Nas and one of my Access points are hardwired via a unmanaged switch into the Lan port of the router.
I have discovered if both my computer and the NAS is on the hardwired side of the router Nat loopback does not work. This includes using a wireless connection to the hardwired AP point. If either or both are connected to the main router via wireless Nat loopback works.
If I use the internal IP address rather than the domain name I can access it ok with both on the hardwired side.
Not sure if this is a feature or a bug?
04-06-2023 05:30 AM
I want to add that this was working for me. I rebuilt the server inside my network and setup up port forwarding again 2 days later and it did not work. I can access the port internally just fine. I can also access the endpoint just fine from outside my network. A "curl -v <url>" showed that it resolved to the correct IP but then nothing. Its a simple tcp 80 -> tcp 80 mapping.
There is not a lot to do to setup port forwarding and I can't imagine how it was different than the way it was 2 days earlier.
04-06-2023 05:58 AM
I was constantly being able to, and then immediately being not able to access my server. I’m not sure if there is even an issue, it’s more than just that the router doesn’t let you connect to it. It’s definitely on google to fix. I just got over dealing with my own server and issues connecting to it so I’m hosting it outside of my net work now.
04-06-2023 12:21 PM
Yeah. Pretty frustrating. I had an original Google Wifi Router (the cylinder) and the merged the config app into Google Home and dropped support for bridged mode. I had to go out and get a new router.
I did not learn my lesson when I bought my Nest Wifi Pro...
05-21-2023 03:00 AM
Any more information about this version? Could you double check the version number and build?
05-23-2023 05:27 PM
Confirming - this appears to be working now for me as well. 1.63.355999
05-24-2023 05:37 PM
Anyone know how to force this firmware upgrade?
05-24-2023 11:08 PM
You can't. But if an update is pending and you reboot it, it will update. You can see firmware update status by going to the IP of the unit in a web browser, then /api/v1/status. Example for my Nest Wifi router main unit:
05-31-2023 08:36 AM
Got the update a couple days ago and it is working for me as well. Let's hope they don't screw it up on the next update.
