04-25-2022 09:56 PM
I set up a nest network with the primary node on my main floor hard wired to the ATT router.
I have two nodes connected to the home node, one upstairs and one in my basement. All have strong signals and when I run a speed test on the google home app it reports 600 MB+ both ways.
However every device connected to the mesh network (laptop, old Mac, multiple iPhones) and all get 50-60 MBs Down and usually 25 or so up.
When I connect to the ATT wifi I get much faster speeds if I am close to the router, worse when I go up or downstairs but still much faster than the google wifi.
Thoughts on what the problem might be?
05-13-2022 10:27 AM
Hi, AndyA1648.
Sorry for the inconsistent speeds you're seeing. I know that can be confusing and frustrating. I have a few questions that might help us figure out what is happening here.
We can dig into this and find out what's happening. I look forward to hearing back from you.
Thanks.
10-20-2022 02:15 PM
Hi Jeff,
I'm having the same issue.
I have the Google home app and the points show great connection but there is a big speed difference. What else can I do?
10-21-2022 01:13 PM
Hi Paul - I ended up turning off my ATT Routers Wi-Fi support to try and avoid any competing resources that may have been in place. That helped some but still not seeing anywhere near the download speed reported by the mesh network. I think some of that is device dependent as well how many devices you have on the network, but that is just a guess on my part.
10-23-2022 10:41 AM
Thanks for posting — let's see what's going on.
Are you using a modem/router combo from your Internet Service Provider (ISP)? How many devices are dropping from the network? Also, do you have any paused devices?
Give these steps a try:
Let us know how it goes.
Mel
10-26-2022 11:02 AM
Hey everyone,
I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Mel
10-27-2022 01:23 PM
10-27-2022 04:18 PM
Hey all,
I haven’t gotten the speed to match with each other but I haven’t had any connection issues.
Thank you for your help
10-28-2022 09:00 AM
I'm happy to hear you're not seeing any connection issues, Paul18. Do you want to keep looking at things to see if we can sort out the speed troubles? Let me know if you want to keep looking into this.
Jeff
10-31-2022 10:38 AM
Hey Paul18,
I just wanted to follow up once more to see if you were still wanting some continued help here. If so, just let us know.
Jeff
11-01-2022 01:53 PM
Jeff
05-17-2022 10:55 AM
Hi, AndyA1648.
Thanks.
05-23-2022 10:31 AM
Hi, everyone.
Thanks.
05-24-2022 08:46 AM
Hi - sorry I missed your earlier replies!
05-24-2022 08:52 AM
Here are answers to your questions:
The most common thing I run into is downloading a 3 - 4 GB game build on my phone and it never gest about 20 - 30 MB/s speed. My co-workers are able to download a lot faster and are waiting on me to finish.
05-24-2022 03:36 PM
Thanks for the info, AndyA1648. That's helpful.
I met with an internal team today and we discussed this. It's being looked into now and if I have any information about this, I'll update here. One thing to check would be the preferred activities setting. Here's how:
Preferred activities remain prioritized for your network until you turn them off.
At this time, I would make sure you don't have any selected. If you do, remove them and see if it helps.
Thanks.
06-06-2022 09:25 AM
Hi again, AndyA1648.
I'm just checking to see if you were able to check those preferred activities and to see if they had any impact on your situation.
Thanks.
06-06-2022 09:13 PM
Hi Jeff - Apologies, I was waiting to see what the internal team had to say about things.
I did check my preferred activities lists and I show Video Conferencing and Gaming, Video Conferencing was checked and I unchecked. it. I did not notice any changes to performance.
Those are the only two options I show.
Note that if I prioritize a device it does make a small impact on its download speeds but it is relatively small.
06-08-2022 03:09 PM
Hey, AndyA1648.
Apologies if you've already checked, but can you look into the WiFi settings in the Home app and see if IPv6 is enabled? If it is, go ahead and disable it and see what impact it has. If it's already disabled (which is the default setting), let me know.
Thanks.
06-08-2022 06:50 PM
Hi Jeff - I just checked and IPv6 is already disabled.
I just turned off the "Wifi router and point usage stats" from the Privacy settings and will see if that helps.
06-08-2022 07:35 PM
A bit more information. I had to download a 19GB game on the Epic Game store so I decided to restart the google mesh router from the Google home device before I started. When it first started downloading it was was great and cruising at 40+ GB, then after a few minutes it ended up running at 10GB or so. That is the speed I typically see.
If I restart the router (Google or AT&T) it seems to work really well for a very brief period of time.
06-10-2022 10:52 AM
Thanks for the added info, AndyA1648.
It's really odd that it's strong and fast for a time and then degrades over time. I'm going to have to continue to consult with an internal team and see what more I can learn here. I'll let you know when I hear more.
Thanks.
07-06-2022 02:22 PM
Hi, AndyA1648.
I still haven't heard back on a possible fix on this. I know it must be frustrating for you, but I wanted to let you know that I'm still searching for solutions. Has anything changed in your situation? If things are better, let me know.
- Jeff
07-07-2022 09:09 AM
Hey, Andy1648.
I'm happy to hear there's been some improvement. Have the new speeds been stable?
- Jeff
07-07-2022 06:59 PM
Consistently better for sure. e.g. - I just did a speed test on my phone in my basement and got 100MB download. Def. not the 500 MB but much better than before.
For reference I forgot to mention I had to restart the google router after I turned the AT&T one off before I saw improvements.
07-07-2022 07:56 AM
Hello - thank you for following up on this. I am seeing better performance the last few days after turning off my AT&T UVerse wi-fi. So now I am seeing 100MB or so download speeds on devices instead of the 20MB - 30MB. Still not at the 500+MB that the google mesh speed test shows but its a definite improvement with that change.
