Nest WIFI router (H2D) appears to throttle both wifi and wired data speeds?
bcmjwsrm
I have a 300Mbps fiber optic internet service and a H2D Nest wifi router.  I am having trouble with the Nest WIFI, which appears to be throttling my data speed to 80Mbps.  I have conducted the following test while only having a single device at a time connected to the router LAN port or WIFI:
1) If I connect my PC directly to the fiber optic gateway device with an ethernet cable, the PC will get 300 Mbps download.
2) If I plug in an old router to the fiber optic gateway device and to my PC, the PC will get 300 Mbps download.
3) If I plug in the Nest router into the fiber optic gateway device, the speed test on the Goolge Home app will show 300 Mbps download to the router.
However, if I run a speed test on any of my PCs or devices connected to the Nest router's ethernet port, I will get ~80 Mbps on the device (using the same ethernet cables I used in the above tests.)   I also get ~80 Mbps on any device when connected to the Nest wifi if the device is connected to the 2.4 Ghz signal.  I can sometimes get much better download speeds if I can manage to force a device to the 5 Ghz signal, but because you cannot name or disable the 2.4 and 5 Ghz signals, most devices will end up on the 2.4 Ghz signal.
If I reboot the router, or if I unplug and re-plug the router to the fiber optic gateway, I can sometimes get the full 300 Mpbs down on any device connected to the router, but that only seems to last a few minuets or hours  before it goes back to most devices getting only ~80 Mbps.
Any ideas on what to do?
21 REPLIES 21
Stevend35
I have this same issue in my warehouse but a little different. I can get 5g connection over iphone with wifi at 300mpbs but if I move upstairs where it might use the mesh point, it drops down to 120mb max.  So I did a little test here at another location where not using google wifi but spectrum wifi box they provide. At 5g I am getting 350mbps but when I switched to 2.4 it dropped to 85mpbs.  No change in distance so that didn't cause anything. No changes other than than band from 2.4 to 5.  I have a feeling google wifi is intermixing the 2.4 and 5g radio bands with some algorithm that is trying to maximize distance trade offs to get most coverage while sacrificing some speed to do it.  I had spectrum come out and test the line, the modem, and it was none of that.  We isolated it to be google nest wifi.  So this mesh system is negotiating this automatically which is why you cannot change it to fixed position. They are doing it for you.  The way to prove this is to get another wifi mesh like TPLINK deco9 and set it up and switch to just 5g and see if you can strong signal to carry that band.  If so, then you isolated the issue that google wifi is the problem.
EdwardT
Thanks for reaching out. I'm sorry to hear that you're having an issue with the speed of your Nest Wifi router. Thanks for letting us know the steps that you've done so far. I'd love to know  more about this and I have a few questions:
  • How often does this issue occur? Does this happen continuously or intermittently?
  • What's the lot area of your home?
  • How many devices actively use the internet at one time?
Edward
bcmjwsrm
Thanks for the input so far.  Here is a reply to the questions you asked:
 This issue occurs continuously, with a very consistent max speed of ~80 mbps.
The house is small and I get a good signal strength in each room but the speed issue is the same no matter how close or far from the wifi router and apply to devices plugged into the LAN port.
There are three people living in the house, one who is a toddler.  We typically are only using 1 chrome cast or computer at a time.  The internet lag is noticeable on a PC that has the 80 mbps speed when compared to a PC that is getting the full 300, even with only 1 device being used at a time.
I have been able to get 300 mbps consistently on a computer by disabling the 2.4g wifi signal on the PC forcing it to stay on the 5g wifi signal.  It will go back to 80 mbps if I plug the computer into the LAN port.
Unfortunately I have devices that do not have a way to force 5g so they have effectively been "throttled" to the 80 mbps max speed.
ianlandmon
Have you tried running a speed test within the App? often after a software update, it will be throttled until you run the speed test in the app
Yeah I have been running speed tests on the Home app and on devices each day to see if anything changes, but this problem has been consistent so far, about 2 months now.
EdwardT
@ianlandmon, thanks for the help!
@bcmjwsrm, thanks for answering the questions. To isolate the issue, let's try disabling the preferred activities. Here's how:
  • Open the Google Home app .
  • Tap Wi-Fi  and then Settings  and then Preferred activities.
Let us know how it goes.
Edward
bcmjwsrm
Thanks EdwardT,
I verified that my Wifi App did not have any preferred activities or devices selected.  I have attached an image of this speed test.  The first run of the speed test was completed while plugged into the router Lan port, the other is a speed test one minute later when the computer was on the 5g wifi signal to demonstrate the issue.
Lan vs 5ghz wifi speedLan vs 5ghz wifi speed
EdwardT
Hi bcmjwsrm,
Thanks for the screenshot. Could you also try doing a speed test with the computer plugged in directly to the ISP's router? Also, please try disabling the preferred activities and check if there are any changes.
Edward
bcmjwsrm
Here is the same speed test when I plug the PC directly into the fiber optic device:
EdwardT
Hi bcmjwsrm,
Thanks for the response. To isolate the issue, could you try changing the DNS on the Google Home app? Here's how:
  1. Open the Google Home app.
  2. Tap Wi-Fi > Settings > Advanced Networking.
  3. Tap DNS.
  4. Select Custom and enter “8.8.8.8” and “8.8.4.4”.
  5. Tap Save.
Edward
Princesss
Hi bcmjwsrm,
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
Princesss
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Wifi and we'd be glad to assist you further.
Princess
bcmjwsrm
I tried the DNS change but no difference in speed tests
I will restart the modem and router and try again, then upload the speed test.
Jeff
Thanks for trying out that suggestion, bcmjwsrm. Once you have done the test after the restart, just let us know how it goes and we'll pick up troubleshooting from there.
Jeff
bcmjwsrm
Here is the speed test after that change to the DNS, no difference.  The 5ghz connection has max speed (top result) but the 2.4 and wired speed are still maxing out around 80-90mbs upload and download.
Jhonleanmel
@Jeff, thanks for the help.
@bcmjwsrm, thanks for the screenshot. To make sure we exhaust our troubleshooting steps, could you try to factory reset your network?
Keep us posted.
Mel
bcmjwsrm
I tried a factory reset, then got the same results.  I did another factory reset and said no to the optional choices during the setup, got the same results.
bcmjwsrm
Here is the result of speed test like before, 5 ghz on top, 2.4 on bottom:
Jhonleanmel
Hi bcmjwsrm,
Thanks for the screenshot and I'm sorry to hear that you're still having an issue with your Google Nest Wifi. We'd like to take a deeper look into this — could you fill out this form and let us know once you're done?
Mel
Ok, I filled out that form.
Jhonleanmel
Hey bcmjwsrm,
We got your form — thanks for filling it out. Keep your lines open as our team will reach out to you via email anytime soon.
Also, please continue the conversation there as this thread will be locked after 24 hours.
Mel
