11-05-2023 06:27 PM
For over a year (since the purchase of our Google Nest devices) we've had issues with internet dropouts. I've gone through an extensive troubleshooting process with my ISP. In short, there are no significant supply-side interruptions to my internet - they're occurring with the router.
I'm running a Google Nest setup with 1 x router and 2 x points. The hardware info is:
The problem is resolved by recycling the power, or eventually, internet connectivity is restored. All have been factory reset several times. I've also changed all the cabling.
The items were purchased in Feb 2021, however, the issue has been running for over a year. At this point, I'm about to seek a refund or replacement under the Australian Consumer Guarantee.
Are there any other options left to try?
11-07-2023 05:05 AM
I am facing the exact same problem. Also wifi points going offline at random. Leaving a reply here to follow this topic.
11-08-2023 11:22 AM - edited 11-08-2023 11:22 AM
@MattD6026, @NGI, that certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? What device are you using to set up your network (iOS or Android)? Do you have the Internet from your modem? Does the child point broadcast the setup Service Set IDentifier (SSID) or network name located at the bottom of the device?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
11-09-2023 01:44 PM
Thanks Dan,
I'm away from my home for a few days but will follow up when I get back.
I've been through most of the steps you've listed. Using iOS to setup.
I'll let you know how I go.
11-14-2023 10:10 AM
Hey there MattD6026,
It sounds like a plan. Take care, and rest assured, we’ll be here when you get back.
Dan
