Second hand nest wifi (not pro) security
Mike777
I have bought a second hand nest wifi router with three access points. Then had a panic about security!
Is there anything I can do to make sure.ita not been tampered with? Is the router more at risk than the wifi points?
Any advice appreciated.
Thanks
olavrb
As long as it's factory reset ( https://support.google.com/googlenest/answer/6246619?hl=en ) then set up from scratch in the Google Home app with your own Google account ( https://support.google.com/googlenest/answer/9548301?hl=en ) you should be good.
I don't work for Google.
AbigailF
Thanks for lending a hand, @olavrb.
@Mike777, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Abi
AbigailF
Hi Mike777,
Abi
AbigailF
Hello Mike777,
Abi
