02-22-2023 02:52 AM
Just had BT fibre 500 installed. When using the BT smart hub 2 only, I get the full 500mbps.
I want to reconnect my existing Google Wi-Fi mesh network, so I removed the BT smart hub 2 and connected the google Wi-Fi router directly into the modem (after changing the PPPoE to BT default). Now my wifi network works, but I am only getting 65mbps.
how can I get the full 500mbps but still keep the google Wi-Fi ??
02-24-2023 08:22 PM
Try unplugging both your FIBER modem and google wifi router, this typically solves the issue.
02-25-2023 09:58 AM
Thanks for the reply, sounds too easy, but actually did work
02-25-2023 09:00 PM
02-28-2023 10:50 PM
Hello Mikem11,
We’d like to check in again in case you have any further questions or concerns. Feel free to reply to this thread and we’ll help you out.
Abi
03-01-2023 10:52 PM
Hi Mikem11,
Abi
