04-01-2024 09:21 AM
My Google Nest Wifi Pro is extremely unstable. I have a 1Gb connection and 2 pucks that state they have a Great Connection yet when I'm on Zoom Calls, I have unstable connection constantly, my streaming TV's buffer like I have a dial up connection. The Speed test shows "Blazing Fast" every time. This is getting to the point where I can not continue to use this to run my business. I need a solution and it's not, Factory Reset. I have done this, I have turned IP6 off, I have reset DNS to 8.8.8.8 and 8.8.4.4 and nothing works. About to go the TPLINK route and get rid of all the Google hardware in my home.
04-04-2024 06:43 AM
Same situation here! Looking at TP Link Deco as well, good reviews and reliability.
04-04-2024 06:46 AM
Yeah, I'm at whits end with this nonsense. It has been progressively getting worse not better and I paid $399 for these. No responses from Google which seems to be par for the course.
04-13-2024 11:10 AM
Hi Everyone,
Thanks for reaching out. I'm sorry to hear you're experiencing problems with your Nest Wifi Pro.
Here are some additional troubleshooting steps you can try:
Hopefully, by trying these additional steps, you can find a solution to stabilize your Nest Wifi Pro network and avoid needing to replace it.
Jonathan
