08-21-2025 11:58 AM
Recently all devices in the home are having a hard time connecting, there is nothing wrong with the internet it's the wifi system that keeps dropping, I have turned everything on and off 100 times. I have downloaded updates where needed, I go to watch TV, says I have no internet and it takes about 3-5, minutes to connect.
This is very frustrating as I have had the wifi nest for many years and everything has been great till now. The real problem is there is no one to speak to and if I can't fix I will have to go to another manufacturer. Please help
08-21-2025 12:10 PM
To contact Support:
3. Select your device from the dropdown, click "Other", then click "Next step".
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
08-22-2025 04:00 PM
I am now having the same problem. Have had these wifi routers/points for a few years now with limited issues, now I have had to restart the wifi router 4 times in the last 2 days. Google products are turning into garbage right ahead of them saying they are going to jack up the subscription cost
08-22-2025 07:50 PM
Same issue here. I’ve had the mesh system for 3+ years and it’s been great. But the last month I have to set the network 2-3 times a day. I have all three mesh piece right above the other one on each floor so 8 to 10 away from each other and it still says there are weak connections. It’s frustrating.
08-22-2025 08:31 PM
Sounds like a software issue because of the consistent timing. Wonder if there was an update that was rolled out recently that is affecting the products. Any tips Sonos?
